RE: Custom canopy for AXE CP??
Fusuno makes a "Custom Painted" AXE CP canopy, but it looks just like the stock one.
Try trimming the lower holes in the canopy into slots, now you just slip the lower slots (in the canopy), onto the lower studs in the frame & clip the upper mounts, quick & easy. If you really want quick battery changes, I made a battery clip (outta plastic strapping)to replace the rubber band that holds the battery. I unclip the canopy, pop it off, pull down the battery-clip, pop out the Lipo, slide in a fresh pack, slide up the battery clip & slap on the canopy.
Shadow
