Trimming (Rudd mix Vs Side thrust)
Hello all
I am having trouble trimming my Pattern model and need advice. My model is a 2x2 Matrix (similar to a CPLR Alliance) running an RX140 with a 16x12 APC.
Is it better to use side thrust or a rudder/throttle mix? How much side thrust becomes to much?
At the moment I have about 3.5 degrees of side thrust and 4% throttle/rudd mix. Up lines and down lines are fairly straight althought with varying speeds the model tracks off line such as through a 1/2 loop.
Also I have trimmed the elevator to give a good vertical downline, while having to hold a far bit of up elevator to maintain level flight, Inverted requires little down elevator stick. Is it better to just hold some stick while level or use a mix?
Help me pattern pros[8D]
Anthony
