? Correct way to hold tx
The first thing I instruct a student to do is to hold the sticks with thumb and forefinger. That's not to say that using just the thumb is wrong, it's just that two fingers gives you twice the control. If you only use one, and you're comfortable with it, then by all means continue, but if you're just starting out, try to get used to using two fingers right away.
