RE: Bob Cat Copy Falcon 120 Jet
i would say no, the extra weight would put more strain on the airframe and landing gear, not only that but the stall speed will increase with the excess weight making the plane much harder to fly.... as well the flight time will decrease do to higher fuel usage. This is a very light built plane, that was designed for pusher prop use, IMHO the worse thing you could do is put an oversized turbine on an airframe like this.
