Battery Setup For 2.4Ghz
Hi Guys.
I have been reading about all the power related issues when going to 2.4Ghz. I understand that the solution is to ensure you have the proper setup. Here is what I use in my jets currently:
Two 6V 1950 Mah Nimh packs each rated to deliver 40 amps (packs from No BS Batteries)
Two Heavy Duty switches
Each switch is plugged into a different port in the Receiver
This setup should give me nearly 4000 Mah capacity and 80 amps of current.
I have over 150 jet flights with this setup and never had a problem. Will this setup be OK with 2.4 Ghz?
Dom
