RE: WILLHOBBY FW 190 Build
JL . if you check the pics in the scale manuals , the rear canopy /top fuse slides with the glass portion .
Unfortunitly most arfs advoid this very critical part of the fuse .
I have a Fw 190 coming from another supplier on Ebay , I will be measureing the fuse from the inside , then removeing the rear fuse and adding it to the canopy ,it will be work but its so obviuos if you have a sliding canopy , if you plan on a fixed version , then no worries
