RCU Forums - View Single Post - Hangar9 Breitling issues
Old 04-07-2003 | 03:56 AM
SloFlight-RCU
Default Hangar9 Breitling issues
I had the same problem. Here's what I did. Take the "Y" and bend it out so it is to big to fit all of the way back into the fuse...as you push it back there, it will compress & then you can just jimmy it around untill both of the pushrods pop out. Alternativly....I recently did away with the single pushrod "Y" design and added 2 servos to the tail of the plane. I've got a OS. 61 up front os balance actually worked out well by just moving the battery a little bit.
