That G&l Hobbies kit is really shapeing up there good james. I see from your last set of pictures you have the wing in place. Did you haft to trim the root of the wing it to fit the side of the fuse like I said you might haft to? Wasn't to difficult was it? Just a little more work in building and you will be ready to fill and sand and do some painting. Excellent build thread. This should help alot of builders with these kits and some others that greg has in his inventory. They build all about the same except the larger models have a two piece fuse but basically the same. I can't wait to get my EDGE- 540 in the air. I think the next build I do will be his 50% Pitts or his 50% Cessna 182. Good job on the build.
Steve M
