RE: Baby Edge Build Thread
An easy way to produce a hole; drill 1/61th holes all around the inner side of the markings; use a sharp #11 blade to 'connect the dots'; and finish up with a sanding drum on the Dremel.
Don't forget the CA hinges, heavily CA-ed in place backing up the screw holes. This will keep the fiber glass from getting weak and cracking around the screw holes.
