ORIGINAL: Steve Campbell
Tom mentions that there should be about a quarter-inch overlap of the cowl over the first former. I have 20mm (almost an inch) at the widest poit; the tape shows the "cut line" where I'll have to grind down the back edge of the cowl.
Pay attention to this; it affects how the canopy deck fits.
I would have thought that putting the canopy deck on and then fitting the cowl and then the engine would work out better and that would eliminate the need to cut the cowl. Maybe I'm wrong, I haven't got mine yet but it should be about the same as the bigger bunnies. The engine box looks a little short. Can you post a dimension of the height of the engine box?
