RCU Forums - View Single Post - G & L Hobbies Extra 300 build thread
Old 12-16-2007 | 06:06 PM
  #48
lrglnman
Default RE: G & L Hobbies Extra 300 build thread
Steve, I made some good progress this weekend. I will post pics later. I got both wings leading edge done . I also got one wings aileron cut out and ready for Robart hinges all I need to do is install the root cap to finish it off and cut the servo pocket and tunnel out for the servo wire. I will be using a aluminum arrow shaft that I sharpened on one end to cut the wire shaft out instead of melting it out. All I have to cut out is about 13" or so. (Steve wrote) "Did you haft to trim the root of the wing it to fit the side of the fuse like I said you might haft to?" Yes I had to do some sanding to get the wing to set flush with the fusealage, but it didn't take alot. I ended up with a nice fit. The 50% Pitts may be my next one as well maybe we can do one together !!!! That would be a great built thread huh? !!!!!
