RCU Forums - View Single Post - Beginner to r\c
Old 12-16-2007 | 08:57 PM
Dokioto's Avatar
Dokioto
Default RE: Beginner to r\c
ORIGINAL: calvino
side note Dokioto didn't mention was that Heat Cycling is more for "pro engines" super fancy fast things, now it may work fine, I would go with the throttle method, neighbor did it with his Savage, no probs...[8D]
I don't see why I would say that...
It is not meant for "pro engines" (whatever you think that is) it is meant for all types of two stoke nitro engines. It has been proved to work better then the old method (run slow then increase speed). It increases the power and the life time of your engine.
Calvino, you may want to check out the link I posted and learn what Heat Cycling is
