RE: WILLHOBBY FW 190 Build
props --two great sources , email Zinger , they make a 3 bladed wooden prop , I think the 180 takes a 16/8 so yes I would check , also check with Horizon , they are very good at there own engines .
The line looks good JL , i was thinking there is a another way of getting a scale looking canopy without cutting the fuse , just add to the existing canopy !!!
All you need to do is take clear plastice , cut and bend it to the cone shape , play with it a little to get the correct shape .Then you can glue it to the original and paint the rear portion (again only if you plan on making it slide ) Now you will have one lone canopy complete with the clear portion and the part that appears as part of the fuse
