Glitches, help needed
Please can anyone help ? I am trying to setup a DL-50 in a PA Edge 540 and I am picking up glitches in my rudder servo (hitec 5955TG). I can only get about 20 paces in a range check with the motor running before the servo starts twitching. I have tried another servo and that twitches. I have even plugged the elevator into the rudder slot (RX) and elevator into the rudder expecting the elevator to glitch but the rudder plugged into the elevator glitched !!!!! I have tried 3 recievers, all give the same results.
I am using a Emcotec DPSI Battery Info Center powered by two 1800 mAh lipo's for radio power and an Emcotec Remote control ignition switch powered by a 1250 mAh lipo. All the radio gear runs down the left side of the fuselage and the Ignition stuff is on the right.
Check out my gallery.
Any sugestions would be great.
