RCU Forums - View Single Post - Rhino Jet Engine Time of acceleration/deceleration
Old 12-17-2007 | 10:11 AM
BluFox
My Feedback: (10)
Default RE: Rhino Jet Engine
Sammo:
Got your email. I look forward to speaking with you this evening. It sounds like the transmitter/receiver is not trained properly. This step must be done properly. Be usre all "Throttle curves" are REMOVED from your Tx throttle channel BEFORE you train the 'Transmitter. You can check the results by viewing the percentages of Low Trim, High Trim and High throttle stick. If trained properly, Low trim should read 00%, High trim about 900 and full throttle stick about 1900 +/-. Also note, if you do not read these percentages, your throttle channel may be reversed. . .I know this is all entry level, but I find we all can overlook the basic's sometimes. . .
Best regards,
Eric
