RCU Forums - View Single Post - G & L Hobbies Extra 300 build thread
Old 12-17-2007 | 07:23 PM
  #50
lrglnman
Default RE: G & L Hobbies Extra 300 build thread
Pic 1 showes the wings installed, sanded to fit the fusealage and the wing tube cut to length.
Pic 2 showes the aileron cut out and test fitted .
Pic3 showes another view of the wing cut with the aileron.
Pic 4 After the aileron is cut from the wing I glued a piece of balsa to the aileron and sanded it to a point the length of the aileron.
Pic 5 showes the wing with balsa glued and sanded to a point as well. this will give me increadiable throw on all serfaces. It will be there if I need it or not. The plans did not call for this but I thought it would be a good idea.
About all I like on this wing is the root cap and hard points on the aileron and cutting out the servo pocket and hole for the servo wire. which I wiil do in the next few nites.
