RE: Sig Citabria
Thanks Dave.
It's all covering. I covered the bottom of the fuselage with white to the stringer below the windows then covered the top with red overlapping the bottom by about 1/2 inch. The wings got white out to the second rib from the tip and the tips covered seperately with red overlapping again about 1/2 inch. The stripes were then cut and ironed on. This is the first time I've used this stuff and it took a little getting used to. I had to experiment with the iron temp a little bit to get it to stick well but it produces a very smooth beautiful finish. I also applied Balsarite around areas like the wing servo openings and anywhere else there was not a lot of surface area to hold it. No worries about bubbles under the trim either.
Minnang
