RE: OS58 1965 Model - HELP!
I'm not familiar with this motor but alot of times there is build up on the wrist pin not allowing the rod to slide back and forth, some types of carburator spray cleaner have been useful getting the gunk off the wrist pin it takes some amount off repeated application and working the rod back and forth to get the rod completely free on the pin witch should on most engines allow you to get the rod off the crank.
gary
