RE: assistance please
Then you need to tighten the brakes. A new battery or servo will not help you with this problem, you need to figure out how to set the throttle up properly. You see the collars on the linkages, you need to move them appropriately. Do whatever you did to fix the idle, then simply tighten up the brakes.
