RE: Glitches, help needed
Two things to try. Set the reciever very close to the ignition box and see if glitching increases. If it does then suspect the ignition is sending wild signals........... Find an older non digital am/fm radio and play it near the plane with the engine running. It should pick up the static from a bad ignition.
