RE: .91FX tuned pipe?
Tuned pipes used in aircraft are usually not broad-tuned like you're used to with R/C cars. The pipes on airplanes are usually tuned for a narrow RPM range at full throttle, and are intended to get the last little bit of power out of the engine.
