ORIGINAL: toro_0397
hi i have been looking for some 3d planes and i really liked the ucd 46. the only problem that i have is that i am not sure if it will hover with a 55 ax since i am flying at 7000 feet above sea level. and if it can hover i wont have enough power to get the plane out of the hover. what engines do you recomend me in order to hover this plane? it can be a four or a two stroke. What props should i use?
the last thing is, the plane really needs a a high torq servo for rudder?
thanks
I doubt that the 46 will hover very well with a 55AX at 7000 ft. Most of all you won't have enough power to with it to be comfortable trying to pull out of a hover.
I've had 4 of the 46's and find the Saito 82 with a 14x4w APC prop to work the best. Maybe an OS 60 would work well on it, not sure.
