ORIGINAL: scubajt41
cant.. when i set the linkage.. the spring prevented the servo from going back to brakes.. i couldnt win either way.. i even messed with brakes for hours yesterday
you need to loosen up the spring slightly so that it will allow the servo to brake if that spring is tight whne the servo is in neutral it will never allow the servo to brake because it is keeping the servo from moving.
