RCU Forums - View Single Post - Intermittant servo on BCX2
Old 12-18-2007 | 03:13 PM
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: Intermittant servo on BCX2
Its the stock TX edge..and i did switch servo leads in channel slots. The forward servo (aka AIL servo) responds in both ELE and AIL slots on the RX. Tis definately the servo and not the 4 in 1. I just found it odd that it crapped out without any glitching or fuss. One day it was fine.....the next it was shot. I will probably end up tearing it apart and see if theres any loose connections.
As far as the TX goes voltage is at 6.1V constant so I am pretty positive its the servo itself. TX glitches tend to build over time unless one has dropped the TX or gotten it wet. For all my other heli's and planes I use my DX6 and with the exception of one of my planks.....glitch free. That one i am convinced is a RX issue and will have to be sent in for repair. I am hoping that HH will honor the warranty on it and fix it for free.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
