Multiplayer Setup
I have AFPD with add-ons#1 and 2 installed on Windows XP. I just hooked up the slave USB cable with adapter for my Futaba T6EX. I can not get the 2nd transmitter/plane to work. I can see the 2nd Tx in the Input Device and Control settings. However, when I try to calibrate, there is no response, the "Calibrate" field is not even highlighted. When I turn the Tx on, I can actually calibrate it!
When I try to fly, I get the split screen. My main GC now controls both planes, again no response from the 2nd Tx:-(
I went to Start-Control Panel-Other Hardware-Game Controller. The "Ikarus GC" and "Ikarus Interface" show up, both with status OK.
Any ideas how to get the 2nd Tx/plane to work? I also tried with my MPX Royal Evo9 with the other adapter cable - same negative result:-(
