RCU Forums - View Single Post - Lozenge
Thread: Lozenge
Old 12-18-2007 | 07:05 PM
allanflowers's Avatar
allanflowers
Default RE: Lozenge
Joe, I just ordered a back issue of MAN with that article. Thanks for the tip.
When you said you tried printing on Koverall, what process did you use? I am thinking of trying dye-sub printing which I think can even go on mesh. I would be very interested in your experimentation with Koverall. The heat could be an issue too, making the fabric pucker up during printing.
Dave, that is a good point about the dope changing the colors. If Koverall (or anything for that matter) is used, doping it may be necessary. The poplin fabric that DPI will print on doesn't heat shrink so dope would be necessary to get it taut. I just bought some to do a test. I think it is butrate dope (Aerogloss flat clear - hope it works).
Dave, I think the model I am thinking of buying is the 1/6 scale version of your design, which was done at 1/4(?) Fabulous design!
