RE: reaming prop
Drill press works for me too. You do need to have the correct size drill. Just getting the size to the nearest 1/16 inch is not close enough. For metric size prop holes (like Saitos require) you will need either a set of metric drills or a set of numbered drills. Numbered drills are easier to find in the U.S.
