RE: Extreme Flight 110" 100cc Yak 54 Build!
Hey all,
After much thought I actually had to relocate the Throttle Servo, even though Chris H. and others have told me that the throttle servo would be fine sitting there between the header pipes. I opted to relocate for two reasons: 1) I wasn't comfortable with the servo and CF linkage soo close the the header pipe, 2) the stock metal blue servo arm as hitting the tuned pipe coupler.
So I built a removable servo tray that can be removed even after gluing the motor box top on. Chris H. says the motor box top can be screwed down, but I have arranged everything in the motor box to be removable and accessable, with the top glued down. Once every thing was done, I had a little more clearance with this set-up. I also used an HS5945 metal geared servo for the throttle. Yeah I know it is over kill on torque, but it is really fast, and I had it in stock.
