Originally posted by captinjohn
I think tapered roller bearings can be used as a thrust bearing...not positive. I wish more model engines had rod bearings with needle type bearings...allowing less oil needed in fuel. Capt,n
The only time I've ever seen them in use, was on a vertical axis which had to bear weight and still rotate. The front thrust bearing on our engines is a prime candidate for tapered roller bearings.
