Tiny Gas Engine
ball bearing much more simple and cheaper -
model engines - setup correctly - have a teensy bit of play in the bearing setups which allow the front bearing to take the thrust load - the rear bearing takes the radial load - on th chain saw stuff - there is still some slop needed - tho which bearing acually handles the axial load is unknown to me - and frankly
I don't care .
