RCU Forums - View Single Post - Tiny Gas Engine
Thread: Tiny Gas Engine
Old 04-11-2003 | 01:51 PM
ZAGNUT's Avatar
ZAGNUT
Default Tiny Gas Engine
in a normal glow engine the front bearing carries no thrust load unless it's used in a pusher configuration or being slammed on with an electric starter, in normal use the rear bearing carries the thrust load. tapered roller bearings are used in pairs and require a spacer between the inner races, this would make a very expensive engine. standard ball bearings carry this small thrust load just fine.
the needle bearings on gas engine con-rods are the simple uncaged type that serve well at low engine speeds, for high speed glow engines a caged needle bearing would be needed but the main problem is finding room in anything smaller than a .90 .
dave
