RCU Forums - View Single Post - reaming prop
Thread: reaming prop
Old 12-20-2007 | 03:52 AM
troposcuba's Avatar
troposcuba
Default RE: reaming prop
as far as centering a drill bit or reamer on the drill press, start with one that is the same size as the existing hole in the prop. put it in the hole, clamp the prop in the vise or whatever you are using to hold it in place, then swap out for the oversized reamer or bit. it will be centered if you didn't move anything. works like a champ.
