ORIGINAL: calvino
ORIGINAL: r\c justin
here is another ?s i bought this fuel its called break-in-fuel i figured it would be best to run it the very first prob run the whole quart what do yall think...
NO, NO, and NO again, just use the fuel you plan on running for the car, 'breakin fuel" is a marketing joke
Yeah he hit that one dead on, its more of a marketing thing than anything else. As the other guy said use it to break in your engine, It can't hurt anything unless they forgot to put the oil in.
On break in follow the instructions that come with the truck, if their are no instructions go to
www.Traxxas.com and follow their instruction, because they are easy and work good. If you don't like those follow the link above any will work and as long as done properly you're engine should run good. If you can find someone near by to help you break in the engine that would be even better and have them teach you how to tune the engine also.
One last thing its called glow fuel or nitro not gas in this case.
