RCU Forums - View Single Post - Herr Pitts Special Kit Build Thread
Old 12-21-2007 | 03:28 AM
  #95
somegeek's Avatar
somegeek
Default RE: Herr Pitts Special Kit Build Thread
Polished up the 2-56 control rods for the tail feathers... can tell the one that is not polished. Used aluminum polish. Quick hit with it makes them look really nice.
Side view of the control rod path.
Top view... sliced a piece of fuel tube down the side and slid it between the servos as they were very close when secured.
Bottom view of the tail feather servos...
Going to cut out this hole in the covering to access the servos and then install a piece of covering over the hole with a 1/4" overlap so removal of the covering to access the servos won't be too difficult. The HS-81 3-hole dual arm horns fit with about 1/4" of clearance from the side covering after cutting off the opposite arm.
somegeek
