prop noise
you might think about a 3-bladed prop. it'll reduce the tip speed per given RPM, thus the noise. bonus, more prop clearance -since power won't be an issue. also, might help be an 'air-brake' at low idle. These are some of the reason's the H9 Alpha uses a 3-blade prop.
