RCU Forums - View Single Post - Glitches, help needed
Old 12-21-2007 | 05:53 PM
  #41
Jake Ruddy's Avatar
Jake Ruddy
My Feedback: (40)
Default RE: Glitches, help needed
A good rule of thumb to follow.... do a range check with the engine off.. then do one with the engine running. Your target should be 90% of distance with the engine off.
Aussie.. I thought about the throttle linkage as well... however with it using a plastic arm on the servo it's not metal on metal. Personally I prefer to use plastic linkage with a ball joint on the carb and plastic clevis on the servo. Many use metal linkage with plastic on both ends... that is the key part.
