RE: Sword 2M pattern plane
Thats texasrcplanes.com sorry. recieved the plane Quality looks good for a $200.00 ARF, the manual is junk looks like it
was printed out on a home PC, the only problem I see with the plane at the start of the project is the tube in the tail for
the aluminum tube for the stab is not square with the fuse, when you slide the stabs on their are large 1/4 inch gaps. wings
look good, covering looks good but color do not match red cowl.
using Evolution 35 because I already have it , had it first in a chip Hyde Tunnel Vission 3d plane that turned out
over weight too, I think I can the plane fliying at under 12lb should fly well at 4hp. I like the evolution 35 engine
but their are not many Arfs made for 35cc engines, and none for 35cc engines with tunned pipes.
Evolution 35 only gets about 3hp with pits muffler da50 get 5hp with pits and weighs less.
pattern plane best fit for engine I could find.
