RCU Forums - View Single Post - Need help setting ESC soft- start..
Old 12-22-2007 | 01:28 PM
xodarap1's Avatar
xodarap1
Default Need help setting ESC soft- start..
Hi,
Does anyone know the generic or standard ESKY ESC menu pattern to setup most ESC's that do not come with program cards?
All I have been able to find out so far is that by powering up the heli with everything connected with the throttle set at full (sounds scary, huh lol) the ESC should enter program mode.
After that, there should be beep patterns that come from the motor (which is cool) to let you know you have entered program mode.
To make changes to a setting, move the throttle to 1/2 stick.
What I don't know is how to tell which menu areas I would be setting and how to navigate the beep/menu system.
Are they all standard for soft-on ramp, brake etc?
I don't want to make any mistakes by setting the wrong pole for the motor.
All I'm really looking to do is set it for soft start and keep all the other stock settings the same as they are.
Any help would be great.
A link to a ESC setup page would be awesome.
*Of course I will doing this with the blades off the bird because full throttle to enter setup mode seems like a dicey way to enter a mode if it doesn't work lol.
Steve
