RCU Forums - View Single Post - Piston rings keeps breaking
Old 12-23-2007 | 01:15 AM
Iflyit
My Feedback: (512)
Default RE: Piston rings keeps breaking
Thanks, I did not notice it was pinned so probably broke it while trying to compress it in place. I know the ring fit as it was on the piston and in the sleeve when I bought it, I thought the piston needed to be removed to put it in the engine. I assume the piston and sleeve assembly can be put together and installed in the case and the rod will slip on the crank?
