RCU Forums - View Single Post - Glitches, help needed
Old 12-23-2007 | 05:38 AM
  #42
Mark Burgess
Default RE: Glitches, help needed
The Edge is still grounded but there is light at the end on the tunnel !!
These are the changes I have made.
-The rudder cables have been separated by a plastic bar.
-The Ignition battery and the reciever battery are as far apart as I can get them while still keeping them in the plane
-The Ignition module has been soft mounted on foam and held on with velcro
Today I tried again, Engine running, with my PPM RX with the above changes............ the rudder glitched at about 20 paces.
I unplugged the Emcotec BIC and plugged a normal RX flight pack directly into the RX............. the rudder glitched at about 20 paces.
I then used a mates JR transmitter and his PCM RX and the Jitter stopped............But went into failsafe at 38 paces, airal down etc.
So now the rudder glitch has gone is 38 paces an OK range test ????
