RCU Forums - View Single Post - DS75H servo replacement and setup?
Old 12-23-2007 | 08:07 PM
choppersrule
Default RE: DS75H servo replacement and setup?
Torquestar,
Futaba and Jr make great servos, just make sure that the dimensions of the servo case are the same. If you replace all of them, you don't HAVE to get the DS(Digital Servo), although they do respond much quicker than the analog servos. Just a little research will fit the bill. Next weakest link, hmmmmm, that would be an educated guess. Seriously, it all depends on how you crash.
Blades, spindle/feathering shaft(getting bent), and small rotor head parts are the most likely. I don't have a B400 or Belt-Cp YET.
I plan on getting one of each next summer just to check 'em out.
Dave / Choppersrule
ORIGINAL: Torquestar
Jeff,
Any recommendations on digital servo replacements? I don't mind replacing the current ones. Especially if I can find units with metal gears!
It seems the servo gear got damaged too easily for such a minor crash.
Where's the next weakest link once you have metal servo gears? Linkage rods?
- brian
