RE: PassTime Perigee Build thread
The final result is a wing that is secured perfectly squared to the body. Next, you need to measure and find out if it is also perpendicular to the sides. A triangle on each side for symmetry will do.
Now that the wing and body are perfect, the next step will be to put the stabilizer on, it needs to be level with the wing, at the correct incidence, and the also squared to the body like the wing before.
