RCU Forums - View Single Post - 50 NG problem
Old 12-23-2007 | 10:33 PM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: 50 NG problem
ORIGINAL: BERTO421
hi mike i think you work for zdz and i need help recently bough e 50 ng but how do you connect the plug with the plug cup the way it is,it is to loss how you make it tigh???? please wrigh to me on rigobenitez@hotmail
You put the plug inside the cup and tighten the plug into the engine. Make sure the little set screw for the plug cap is in front so you can access it. The plug is supposed to be torqued to 15 ft-lbs. Then the plug cap is held in with that little set screw. That's all there is to it !!!!
