RCU Forums - View Single Post - Glitches, help needed
Old 12-24-2007 | 12:16 AM
  #49
Mark Burgess
Default RE: Glitches, help needed
I have tried 2 plugs and there was no change. Obviously I used the original plug that came with the motor. I also have tried a NGK CM-6. The NGK is not a resistor plug. Iv'e been told that the plug lead has a built in resistor and the cap is shielded as well as the lead. I recon I need to try a different Ignition. Its the only thing left....
Mark
