RE: DL50 engine
If it stops in 5 seconds it's not heat related.
I would tend to think that you have the linkage to the carb backwards or something silly like that. Get a dental mirror and look through the open choke to see where the throttle plate is with it at idle and at full power. When you look in the carb you should see the threads of the throttle plate's screw, not the head of it.
