RCU Forums - View Single Post - Center of Gravity "CG" Computations
Old 12-24-2007 | 05:58 PM
RC Specialties
Default RE: Center of Gravity "CG" Computations
You are absolutely right. There is always a most forward and most aft cg limit (cg range). Loading can vary to keep the cg within that range. However, in RC airplanes the real only variable is fuel loading. The empty weight cg can be an exact one. It can be adjusted to get the best flight/performance for the full fuel to empty range.
Jim
