ORIGINAL: daviesjim
could anyone tell me how to get the main rotor gear off the main shaft. I,m down to the sawish plate and have taken the nut and bolt off also lossened the set screw on the collor and the shaft moves up and down but short of driving it out with a screwdriver and hammer I'm at a loss . I don't want to brake something while trying to get it out. I'm new at this, its trial and error. THANK YOU Jim
you can use some of slightly smaller diameter to push up on the shaft and at the same time kinda wigle the gear pushing one side up one down back and forth till it comes out it will come pout but slowly, or if you have smooth jaw pliers you can grasp the top of the shaft and aplly back and forth movement while pulling up and wiggling the main gear
