RCU Forums - View Single Post - over powered
Thread: over powered
Old 12-24-2007 | 10:14 PM
aerowoof
Default RE: over powered
would you mind explaining what you are doing in the above photos,some I can tell that you are cutting the case to make it compact but some I am lost.like the flywheel,I am guesing you removed the cooling fins but did you also make it smaller in diameter since there was no need for the magnets if you went ei?
