RCU Forums - View Single Post - Help with Harrier
Old 12-25-2007 | 07:12 PM
CJQ
Default Help with Harrier
I'm just starting out with 3D, I've been told to start out with learning the harrier. I can get the plane to harrier with full elevator and about 1/3 throttle, but it tends to rock from left to right pivoting about the centre line of the plane, so then I'm putting in ailerons to try and counter act it with success sometimes but other times it will completely roll over. The other thing I find is at times instead of rocking it will try to turn to the right and I'll have to have full ailerons to the left and even some rudder to keep it straight. I flying a E flite 260 3D 480 and the CG is setup right. Is there some other adjustments that need to be done on the plane or just in my head, the pro's make it look so easy but I imagine they have spent hundreds of hours to perfect a maneuver. Any help is appreciated
