RE: sts 28 starting problems
270 is a little on the higher end of the temp range for a 28. It sounds like you piston my be swelling inside the sleeve. Is it harder to pull when it is hot? If it is try running a cooler temp plug and bring your engine temp down. Hope it helps.
